More chatting
I want to add a feature that you can send more messages
Hi there, @Eiland-survival :wave:
You see, AI feature is really expensive, and each generation comes with its additional costs, that’s why we’ve decided to set such limits now.
If you’d like to increase the message limit, you should upgrade your subscription to a higher plan:
