Mobile Phone and Tablet Views Same As Desktop View
Greetings Team,
The issue I have is that the formatting on tablets and mobile phones changes from a single video view on desktop browsers to multiple thumbnails of all the videos in the playlist.
Is there are a way to keep the same single video formatting view on tablets and mobile phones, like the desktop view of the Elfsight widget when configured that way?
Best wishes,
mw
Hi there, @iammasterweb :wave:
You can adjust the mobile optimization on the Layout tab:
Give it a try and let me know how it worked :slightly_smiling_face:
Thanks @Max. I try it and let you know.
So @Max I tried it, and it seems to work. However, I just want to confirm that both listed default values in Mobile Optimization should be changed to 375px? The Elfsight dashboard doesn’t show how the widget would render on a Tablet.
Best wishes,
ms
You should add the breakpoint values depending on a window width on your device (tablet or mobile):
Thank you @Max.
You’re welcome :wink:
