Menu navigation (navigation bar)
@Matteo, do you mean you need a header menu that unfolds more options when hovered over or clicked? If so, could you please describe how you’d like to customize this menu and what specific options you’d like to add there?
Hello check this out:
@Matteo, my apologies for the delayed reply :cold_sweat:
Many thanks for the example! Hmm, it sounds like you need to get a full custom page to open when clicking on the hamburger menu, got it.
It all looks really nice, but I’m unsure if this very scenario will be supported in the first release due to its complexity. But we’ll keep this use case in mind though, so thanks a lot for sharing :slight_smile:
Share your use case and provide as many details to support your idea as possible. Thank you! :blush:
The extension that allows you to add a navigation bar to the body of a webpage, instead of the side or top. this extension adds a customizable sidebar that can be positioned anywhere on the page and remains visible as you scroll.
Hey there, @Pilot_Test :wave:
The idea for the Navigation Bar app is already on the Wishlist, and we’ll try to consider the floating layout option when working on it.
I’ve moved your comment to a dedicated topic, where we’ll keep you posted :slightly_smiling_face:
Is there any sort of ETA? I’m a bit worried because this thread has been active for about 5 years
Hi there, @jordan-kylate :wave:
I wish I could share the ETA, but, unfortunately, this app isn’t on our roadmap yet.
The thing is that when prioritizing requests, we have to balance between their popularity and complexity. Right now, we have a bunch of requests with the higher priority and devs are focused on them.
The good thing is that we’re really ramping up our efforts to work on new apps and only this year we’ve released 9 new widgets, which you can find in the New Widgets section. And chances are, we’ll roll out even more!
So, let’s hope the devs will be able to include this idea in the roadmap, and I’ll make sure to update you here in case there are any news :slightly_smiling_face:
A huge thank you for sharing your feedback with us!
I really need this widget for several projects as well. Something similar to www.dropdownmenugenerator com would be a much needed and excellent addition to your widgets!
Hi there, @Ken_Knecht :wave:
Thanks for upvoting the idea and sharing your example - that’s much apprectiated!
It would be great if you can create this customized widget for a wordpress website mobile header.
Hi there, @Mona_Zahra :wave:
Could you please share an example of the header you’d like to have?
A header that can be customized. Which has a menu and a logo. Where you can add to it extra options as well maybe location or phone number…
You have something similar which is the announcement bar but there you can not add a website menu.
Got you, thanks!
We already have a similar idea on the Wishlist. I’ve merged your topic with the related discussion, where we’ll keep you posted :slightly_smiling_face:
@Valentine_Pillay, A huge thank you for sharing the details :+1:
Glad to say that we already have a similar request on the Wishlist! I’ve merged your comment with the existing thread, where we’ll keep you in the loop :slightly_smiling_face:
Excellent suggestions,
I would like also to see the capabilities to add sub menus to the original menu.
Nice idea! Thank you everybody for sharing your thoughts!
I also think about big and nice menu header with hover effect. Adding pictures as option too!
Also being able to set links nofollow is vital because menu links will on each page of the website… so its vital to be able to navigate internal linkjuice.
Thanks a lot for your comment, @Darius!
As for pictures, do you mean icons next to headers or something else? If you have an example, feel free to share! :blush:
Thanks, @Stefan_Cronjager, looks great! I think this is how we also see it in action :slight_smile:
is there a timetable for the navigation menu widget to come to light?
