Manually Order Staff
I would really like to be able to manually order how the staff appear in our ‘Team Showcase’ from most experienced to least experienced.
At the moment, some of our least experienced staff are appearing first. Unless I’m missing something, there seems to be no way to edit the order.
Greetings @Marketing_Inspire :wave:
Glad to tell you that you can do this right in the configurator. For example, if you want to display Alex first and Liam second, you just need to click on Alex and drag it above Liam:
