Loox reviews integration
Would be amazing if we can add reviews from loox. this would really help ecommerce sellers
Thanks a lot for your suggestion, @user1783! We’ll try to include Loox in our future updates :slight_smile:
And welcome to the Elfsight Community, very happy to have you with us!
Be able to integrate reviews from “Loox” platform in the All-in-one reviews. Loox is a Google certified review app and adds review snippets.
Hey there @user152 :wave:
Many thanks for adding your idea to the Wishlist!
If this request gets more votes, we’ll try to consider implementation of the Loox source in one of our future updates.
i want loox testimonials. Thank you! :blush:
Hi there, @khaled_AH :wave:
Glad to say that we have this idea on the Wishlist. I’ve moved your comment to a discussion, where we’ll keep you updated :slightly_smiling_face:
As a temporary solution suggested above, you can use a Custom source option in our All-in-One Reviews app to add the reviews manually.
