The height seems arbitrarily limited and the controls do not scroll down past the limit, making longer lists unusable
Thank you so much for bringing this to our attention!
Our devs are already working on this issue and the fix is going to be released quite soon. We’ll keep you updated
Hi there @Brad_Halferty
The issue is fixed! Please check your widget and let me know if it’s fine on your end
