Lazyloading images and avatars
Increases page-loading speed by deferring the loading of off-screen images. Helps literally every single Elfsight customer. Simply add “loading=‘lazy’” in the html img tags. 2 second amendment to your backend and EVERYONE benefits with better search results ranking.
Original Votes: 4
Original comment from Clint Bohaty transferred from the previous Wishlist portal:
Hello folks!
Big news is coming — lazy load beta version for embedded widgets is here! :heart_eyes:
It doesn’t work as a built-in option yet due to a couple of unresolved matters, but you can adjust your widget manually in order to make it work :slight_smile:
Although this solution applies to the whole widget, we still believe it might work for you.
To turn it on, please add the “data-elfsight-app-lazy” attribute to a
element in your installation code.
For example, here’s how the code looks like initially:
<script src="https://apps.elfsight.com/p/platform.js" defer></script>
<div class="elfsight-app-9d3beb9e-4c72-4bd1-8ed6-c192fc9e56c7"></div>
And here’s how it should look like with the attribute added:
<div class="elfsight-app-9d3beb9e-4c72-4bd1-8ed6-c192fc9e56c7" data-elfsight-app-lazy></div>
Please keep in mind that it will work only for widgets which are not in the initial viewport (e.g. users have to scroll down at least for a little bit before they reach the widget).
Please let us know if it worked on your end and what you think about this option :slightly_smiling_face:
Where’s the example?
@Billy my apologies for this! It seems the codes have been lost when transferring.
I’m duplicating the lost extract:
<div class="elfsight-app-9d3bXXXX-4c72-4bd1-8XXX-c192fc9eXXXX"></div>
<div class="elfsight-app-9d3bXXXX-4c72-4bd1-8XXX-c192fc9eXXXX" data-elfsight-app-lazy></div>```
Hi folks!
I’m closing this request since the solution described above does resolve the issue :slight_smile:
Just in case, here’s the post where we explain a lazy loading feature in more detail: You now CAN improve your PageSpeed :rocket:
