Please introduce lazy loading so widget will be able to play greater number of audio files smoothly
Folks, our former Wishlist portal, where our users shared their requests and suggestions, was transferred to this forum. You’re most welcome to vote, add new ideas, and leave your comments here — we surely will consider them all! ![]()
Original Votes: 7
Hello,
Thanks a lot for adding your request!
I do understand your point and I also think lazy load would be a great solution. We’ll try to add this task in one of our future updates ![]()
Thank you for helping us!
Helga, Community Manager
Keep up with latest updates - Facebook (https://elfsig.ht/3zUsqBa)
Get to know our team - Instagram (https://elfsig.ht/2VmJNf9)
Hello folks!
Big news is coming — lazy load beta version for embedded widgets is here! ![]()
It doesn’t work as a built-in option yet due to a couple of unresolved matters, but you can adjust your widget manually in order to make it work ![]()
To turn it on, please add the “data-elfsight-app-lazy” attribute to a
For example, here’s how the code looks like initially:
<script src="https://apps.elfsight.com/p/platform.js" defer></script>
<div class="elfsight-app-9d3beb9e-4c72-4bd1-8ed6-c192fc9e56c7"></div>
And here’s how it should look like with the attribute added:
<div class="elfsight-app-9d3beb9e-4c72-4bd1-8ed6-c192fc9e56c7" data-elfsight-app-lazy></div>
Please keep in mind that it will work only for widgets which are not in the initial viewport (e.g. users have to scroll down at least for a little bit before they reach the widget).
Please do let us know if it worked on your end ![]()
Hi folks!
I’m closing this request since the solution described above does resolve the issue ![]()
Just in case, here’s the post where we explain a lazy loading feature in more detail: You now CAN improve your PageSpeed ![]()
