Layered Popup
Hi there :slight_smile:
It would be awesome to be able to add layers to the pop up. I might have missed that funcition, if so, please let me know :slight_smile: F.ex. I would like to have the option (within the Popup) to add two or more buttons, when clicking button1, it slides within the popup to iframe1 and if clicking button2 it reveals iframe2…
Let me know if that makes sense :smiley:
Thanks and keep well,
Kris
Hi there, @Kristoffer :waving_hand:
I see that you have 2 Popup widgets and each of them has only one iframe element. Would you like to combine them into one widget?
If yes, please specify the name of the widget that should be customized. Our devs will try to help you with it :slightly_smiling_face:
Hi @Max :slight_smile:
That’s awesome, thanks! Give me a couple of days to get it ready for you guys to look at :smiley:
