Larger window for event calendar description field
It would be extremely helpful and efficient to have a drag and expand option for the description field in the events calendar. The window is so small that you have to scroll slowly to make edits or you’ll miss the text you want to change.
Greetings @user2776 :wave:
I do see your point, and I’m very sorry that our widget doesn’t have this functionality We’ll try to consider this enhancement for the description field. We’ll keep you in the loop here :slightly_smiling_face:
A huge thank you for pointing us in this direction!
Any updates regarding this topic?
I experience the same issues regarding the small text field.
Looking forward!
Cheers,
Lucas
Hi there @user8832 :wave:
Unfortunately, we haven’t got any news regarding this feature yet. Once anything comes up, we’ll immediately let you know in this thread :slightly_smiling_face:
Many thanks for pointing us in this direction and yes, welcome to the Community!
Thanks Max! I’ll keep my fingers crossed.
Have a good one!
Would love to see the ability to expand the event description. It is so difficult to add text and change formatting in this itty-bitty narrow field.
Thanks for pointing us in this direction, @pammy51788 :waving_hand:
We’ll keep this idea in mind and update you here in case of any changes :slightly_smiling_face:
