Language customization
Dear Team,
Good Day!
Can we use the language of the menu Arabic and English both on a drop-down.Kindly Let us know the details for this.
Thanks,
Paris Group.
Welcome to the Community @Dev_PG :wave:
Do you want to have 2 different language versions of your website? So, that when loading the dropdown appears, you choose the needed language and all the website’s elements get translated (including Restaurant Menu widget)?
Or maybe you’d like to translate only the widget? If it is, please specify where you’d like the dropdown to appear. A screenshot of what you mean would be highly appreciated :slightly_smiling_face:
Hi Elfsight,
Yes, we want a dropdown where we can change English and Arabic as needed on top of the menu. I have attached the screenshot as well.
I appreciate any help you can provide.
Lusaka Bhattacharyya.
developer pg.
We only want the widget to be changed to English and Arabic as needed.
Thanks,
Got it!
This is a really cool suggestion but, unfortunately, there is no option to customize the widget this way at the moment. We’ll try to consider this opportunity in the future.
I’ll keep you abreast of any changes here :slightly_smiling_face:
