Hey, You made improvements is good but we are in trouble to fill phone number in my live website form. I can’t fill all 10 digit excluding country code. please resolve in High Priority.
Check this link : ( 0% Financing Available For Kitchen - Apply for Credit | Express Kitchens )
Max
November 13, 2025, 6:22pm
2
Hi there, @user16900
I am so sorry for all the inconvenience caused!
I’ve just tried to add a 10-digit (without a country code) number to your form and it worked fine:
If I misunderstood the issue, or it works differently on your end, please share a video screencast of what you mean. I’ll gladly investigate it for you
Hey,
I can not enter last 3 digits. Please check attached screenshot.
Max
November 13, 2025, 6:34pm
4
I’ve managed to replicate the issue, thank you so much for sharing a screenshot!
I’ve forwarded it to the devs and will update you once it’s fixed
Hey, I’m using this and works 100% since it has been implemented. Just tested again on my side, print attached
Max
November 13, 2025, 6:53pm
7
Hmm, thanks for sharing your insight, @user5015
I’ve tried to add the number from your screenshot to the widget of @user16900 and the issue still persists there.
This makes me think it might be just a website-specific issue, but our devs will investigate it, and I’ll share their response in this thread.
Thanks a lot for your involvement, we really appreciate it
Max
November 14, 2025, 10:57am
8
This issue occurred because of the script added to the Custom JS field on the Settings tab to set a limit for the number of digits.
We’ve temporarily commented (disabled) it, so everything works fine now, but we recommend you removing this script from the widget:
Please check it out and let me know if everything is fine now
