Issue with form submissions
I can no longer submit forms.
Hi there, @Marc_Schurmann :wave:
Could you please send me a link to the page where your widget is installed? I’ll be happy to check things for you!
Hi Max
Thank you for help. The form is here: Dein Feedback ist wichtig | BMW IBU WM Biathlon Lenzerheide 2025
If you click on send there will be no success message and no e-mail will be sent.
Hi @Marc_Schurmann :wave:
I’ve tested your form and the submission was successfully sent:
If the issue still persists on your end, please take a screenshot of the Developer Console right after clicking on the Submit Button and send it to me :pray:
Hi Max
Here is the printscreen of the console
Could you please check your website in incognito mode and let me know if the issue still persist?
Hi Max
Works find in incognito Mode with Edge and Chrome. So could it be a local Problem of my device oder network?
Cheers
Marc
Got it, thanks!
Please try to clear cache and cookies in the browser where the issue occurs. If the issue still persists, it is most likely caused by your browser’s extensions.
Please try to disable them one by one and let me know if it helped :slightly_smiling_face:
Hey Max
Great, now it works very well.
Thank you.
Cheers
Marc
No sweat!
If anything else comes up, we’re here to help :slightly_smiling_face:
