Max the exceptions does not work with all events, or something. Most of my events are recurrent or repeated events, for the Warm Center I was able to add exception for upcoming holiday Monday Feb 16. But when I try to do same thing for Zumba or Daily Senior Lunch it does not show anything on the exceptions tab
Hi there, @Norton ![]()
Many thanks for flagging this up!
I’ve shared this issue with the devs and will update you once it’s fixed ![]()
Thank you for wating!
While our devs are working on the global solution, we’ve applied a local fix to your widget. Could you please check it and let me know if it’s fine now?
Once the global fix is released, we’ll update you in this thread ![]()
@Max is working now as intended, thanks!
Awesome, you’re always welcome ![]()
