Issue with AI form
Thx. The provided info from the customer is not visible. Also the name tags does not work correctly. is does not show the real name. but just “name”
Hi there, @user3229 :wave:
I’ve tested your widget, by adding my email as a receiver and the form details appeared on my end:
Could you please double-check it and let me know if the issue still persists?
As for the name tags issue, could you please elaborate on what you mean?
If I use the standard English it works. when you use an other language the tag name is replaced in that language. so you need to replace it with “name”
Ah, got it! You can change the form field labels in the Language section on the General tab:
Let me know if you have any questions left :slightly_smiling_face:
