- Issue description:
The client has deleted something on Instagram and it is not syncing down - anything that we need to do on our end to make this work? - Link to the page with the widget in question:
- https://yourcareitsyourhome.life/*
Hi there, @user20713 ![]()
Apologies for the inconvenience! We’ve removed the deleted post from your widget:
If any further assistance is needed, we’re always here to help ![]()
Do we have to do this each time a post is deleted or will it automatically remove them moving forward?
Matt
Getmilk Guru
The deleted posts don’t disappear from the widget right away because of the cache. The cache time is 48 hours and after this period the post should be deleted from the widget too.
If you want to remove it from the widget faster, you can try to readd your Instagram source in the widget or reach out to us again ![]()
