Archived Posts
All posts are constantly being displayed. Even though I have archived several posts on Instagram, they are unfortunately still showing up in the feed.
Also the sync time didn’t work. I’d have to disconcet and reconect with my acocunt to show the new post.
Hi there, @Elmar_Vigl :waving_hand:
The archived posts don’t disappear from the widget right away because of the cache, which is 48 hours in our app.
I’ve tried to add your profile to my test widget using the Account connection and it displayed the posts that are currently available in your Instagram profile only:
To remove the archived post from your widget, please try to completely remove your source (not just reconnect it) and add it again:
If it doesn’t help, please specify the posts that should be removed. Our devs will gladly look into this :slightly_smiling_face:
