I would like to retrieve reviews from multiple sources, but the majority of the companies in Glassdoor and Indeed require a personal log in. So, although I see the reviews, the widget is not retrieving them. How can I bypass this?
Hi there and welcome to the Community, @Roxann_Bloemendal ![]()
I’ve checked your widgets and here are the sources, where the reviews are not being collected:
https://www.glassdoor.nl/Reviews/NN-Belgium-Reviews-E4789168.htm - Global Belgie widget
https://es.indeed.com/cmp/National-Nederlanden/reviews - Global Spanje widget
https://www.glassdoor.com.hk/Reviews/Nationale-Nederlanden-Reviews-E559186.htm - Local Review snippet
https://www.glassdoor.com/Reviews/NN-Group-Reviews-EI_IE982653.0,8.htm - - Local Review snippet
Unfortunately, Spanish domains are not supported for the Indeed source, that’s why the reviews haven’t been collected. I’ve added this idea to the Wishlist, and we’ll try to consider it in the future updates - Add support for Spanish (es) domains for the Indeed source
Regarding the Glassdoor sources, the issue with this source has been resolved, and the reviews are now available in your widget.
As for the other Glassdoor links, unfortunately, only .com domains are supported there. I also agree that it would be awesome to implement the support for .nl and .com.hk domains and I’ve added these ideas to the Wishlist as well:
As a workaround, you can replace .nl and .com.hk in these links with just .com and the reviews will be collected.
Please check it out and let me know if it helped ![]()
P.S. I’ve also noticed that you’ve chosen the Indeed source for the Glassdoor link in the Global Belgie widget. So, to make the adjusted link work fine, you should remove the Indeed source and add the Glassdoor source for your link:
This is the best advice I have been given in a very long time, much much appreciated!!
Curious to find out what will come out of the feature requests!
I am so happy to know these tips worked for you! Thanks a ton for your amazing feedback, @Roxann_Bloemendal ![]()
By the way, we’d like to invite you to participate in our Christmas Giveaway, where you can win a 3-month extension for your subscription - Christmas Giveaway: Win 3 FREE Months (10 winners) + 1 month guaranteed! ![]()
If any other company in this world was halve as fast as you guys, this world would be a lot more fun.
I am very very grateful with this and your support! ![]()
I wish you all the best this Christmas and in the new year to come!
Wishing you a Christmas season filled with love, joy, and here’s to a fantastic New Year ahead ![]()
