Indeed and Glassdoor reviews
Wanting to display Indeed and Glassdoor reviews
Hi @Clinton_Large, great to have you join the community! :waving_hand:t2:
Our All-in-One-Reviews widget includes both sources, and I see that you’ve already tested it. I also see that the link you added doesn’t work - that’s because our widget supports only .com links at the moment.
I’ve changed the link in your widget and it worked fine for me. Could you please check it on your end as well?
If you have any other questions, I’ll be happy to help :slight_smile:
