Hello I’d like to create a product calculator for tile grout materials. Customers have to input the area of the room in sq ft however, the max value only goes up to 500 and I need it to go up to 20,000 sq ft. Can you help?
Hi there, @user19773 ![]()
You can set Min and Max values right in the field’s settings:
@Max I can’t seem to figure out how to get the Max Value to go over 999. Ideally I would like to go to 10,000. Any advice?
Hey there, @Ben_Taylor1 ![]()
You just should click on the Max value and manually add the needed value:
Try it out and let me know if it helped ![]()
