I would like a Product Estimator Calculator. For example a calculator to estimate how much paint is required to paint a 2500 sq ft house if the paint covers 200 sq ft per gallon.
Hi there, @Western_Log_Home_Sup and welcome to the Community ![]()
Glad to say that the AI Calculator Generator is built into our app. So, you just should describe your idea and the AI Generator will build a calculator based on your needs:
Please try it out and let me know how it worked ![]()
If the generated calculator doesn’t fully cover your idea, please describe your use case in more detail and we’ll try to help!
