I was hoping i may be able to get some help with a very specific testimonial design.
I am wanting to do something like this. I know this may require a bunch of CSS coding but I was looking at the current Elfsight slider and seeing what things would need to be changed.
Arrow style and location would need to move.
Product photo would need to frame into the full container on the left side.
Quotation mark would need to be added
Custom font, font size, and font spacing/location
Most importantly, moving the customer/client photo to the right, increasing the size, and making it a rectangle vs circle.
I’d like to say that our Slider widget would be a better option for this case.
Using the Slide Builder slide type, you can add different elements like images, texts, headings, buttons, separators, etc and control how they’re displayed (alignment, size, font settings are available there):
However, it will still require some CSS codes in order to display images properly on all devices. Could you please add the needed content (texts, images, etc) to the Slider widget and let me know once this done.
After that, I’ll pass your request to the dev team
