Changing Arrow Style and other CSS on Testimonials
Hey there @Max and @Helga!
Hope you have both been well!
I had a few questions about some quick customizations! I was hoping you might be able to help me with an SVG customization of the arrow. Essentially instead of the chevron i was just wanting ← → so it matches the site branding.
Next, is there a way to target specific font changes? For instance, I’d like the actual quote to be one font, but the author name and title to be another. Also applying a color to these
Lastly, I was hoping to add a line to only the TOP and BOTTOM of the container so it looks something like this… if the arrows can be under that line, EVEN BETTER, but if not I totally understand! i would also love to add that sort of border radius to the image and a small border to match.
I should add that the site is not live and that this is the “Untitled Testimonials Slider”.
Hi there, @Quilla :waving_hand:
Unfortunately, it’s impossible to implement this customization using a Testimonials Slider app, but it’s possible to do this using our Slider.
To change the style of the arrows, please add this code to the Custom CSS field:
.eapp-slider-arrow-component {
  background: transparent;
  box-shadow: none;
.eapp-slider-arrow-component svg {
  display: none;
.eapp-slider-navigation-previous .eapp-slider-arrow-component::after {
  content: '←';
  font-size: 32px;
.eapp-slider-navigation-next .eapp-slider-arrow-component::after {
  content: '→';
  font-size: 32px;
.eapp-slider-arrows-container {
  gap: 16px;
I see that you’ve started working on this customization and added an image, texts and separators. It’s also possible to apply a different setting to each text element right in the settings:
To make these options work, please remove your CSS codes, changing text font and color. Check it out and let me know if it works for you :slightly_smiling_face:
