I want to create more than one widgets
i really want to make more than one widgets or forms. can i get that?
and another question is is it possible to make the questionnaire’s in slide format for a free version ?
Hi there and welcome to the Community, @Faiza_Faiza :waving_hand:
With the Free plan, you can create just 1 widget per app (for example 1 Form Builder, 1 Instagram Feed, etc) . If you need multiple widgets, you can upgrade to a paid plan. You’ll find details on the widget limits for each plan in the Pricing section:
For the slide questionnaire, you can easily set this up using the Multistep layout:
Give it a try and let me know how it goes :wink:
for the slider version is it mandatory to click the next button or can i make the slides to move to the next slide automatically?
Do you mean to automatically open the new form page, when all the fields on the current page are filled?
yes like that.
for example when i answer the first question then the system automatically open the second question slide
There is no such an option in the settings, but I’ll ask the devs if it’s possible to create a script for this custom behavior.
Just to confirm, would you like to keep the Back/Next buttons in the form to let clients change pages manually if needed?
