I can't create airb's review widget
  • Issue description:
I would like to have airb reviews displayed on my friend’s site.
I set up it, but an error is displayed.
“No reviews found. Please make sure the source is correct, that it has reviews and that filter settings do not exclude all the reviews.”
I already wrote the URL and Airb also comes with reviews.
Are there any other possible problems?
Hi @user11890 and welcome to the Community :wave:
Our widget support only .com links, that’s why the reviews haven’t been found. If you try to use this link (https://www.airbnb.com/rooms/14164939) instead, all the reviews will be displayed:
Let me know if this clarifies the situation or if you have any further questions :slightly_smiling_face:
