Error Airbnb review
Hi, unfortunately the airbnb reviews do not load in any way …
Hi @Ferdinando, I’m really sorry for this :frowning:
You know, I see that you also opened a support ticket, and my colleague Anastasia has already responded to you there. Just in case, I’m duplicating her reply here:
I’m very sorry to inform you that our reviews widgets accept only .com links. Unfortunately, all other country domains are not supported due to some technical restrictions, please accept my apologies.
However, I’m happy to say that I converted your link into .com and used it in the widget.
I’ve just checked it and everything seems to be working fine.
I really hope you’re good now :slight_smile:
