How to make a Slideshow randomize
To make a slideshow randomize in Squarespace, you can follow these steps.
#1. This code supports all types of Gallery Slideshow: Simple + Full
#2. First, enable Slideshow Caption
#3. Edit First Image in the Slideshow and add this text to the Description field
twc-gsior
#4. Use this code to Page Header Injection (Page where you use Slideshow)
      gallery section image order random
      License       : < https://tinyurl.com/s872fb68 >
      Version       : 0.2.0
      SS Version    : 7.1
      Dependencies  : jQuery
      By            : Thomas Creedon < http://www.tomsWeb.consulting/ >
      no user serviceable parts below
      const version = '0.2.0';
      const s = `Gallery Section Image Order Random v${ version }, ` +
        'License < https://tinyurl.com/s872fb68 >, ' +
        'Tom\'s Web Consulting < http://www.tomsWeb.consulting >';
      console.log ( s );
    const codeKey = 'twc-gsior';
    const selectorPrefix = '.gallery-section ';
    const selectorSuffix = ' .gallery-caption ' +
      `p.gallery-caption-content:contains(${ codeKey })`;
    let selector = selectorPrefix
        '.gallery-fullscreen-slideshow',
        '.gallery-grid--layout-grid',
        '.gallery-masonry',
        '.gallery-reel',
        '.gallery-slideshow',
        '.gallery-strips--layout-strips'
      .join ( `${ selectorSuffix }, ${ selectorPrefix }` )
      selectorSuffix;
    const $elements = $( selector );
    if ( ! $elements.length ) return; // bail if no $elements
    const $galleries = $elements
      .parents ( '.gallery-section' );
    let callback = function ( ) {
      const $this = $( this );
      let text = $this
        .text ( )
        .replace ( codeKey, '' )
        .trim ( );
      if ( text )
        $this
          .text ( text )
        else
          $this
            .parents ( 'figcaption' )
            .remove ( );
    $elements.each ( callback );
      const callback = function ( ) {
        const r = Math.floor ( Math.random ( ) * $images.length );
        const $image = $images.eq ( r );
        $( this )
          .append ( $image );
        $images = $images.not ( $image );
      const selector = [
        '.gallery-fullscreen-slideshow-item-img',
        '.gallery-grid-item-wrapper',
        '.gallery-masonry-item-wrapper',
        '.gallery-reel-item-src',
        '.gallery-slideshow-item-img',
        '.gallery-strips-item-wrapper'
        .join ( ', ' );
      const $elements = $( selector, this );
      let $images = $( 'img', $elements );
    $galleries.each ( callback );
This is great, I’ve been trying other solutions to no avail. This solution looks like you can’t use captions, however, because you’re using the description field for the “two-gsior” tag. Any way around that?
I just created another example but with Gallery Block Slideshow + Caption, you can check it here
https://phuongvit.squarespace.com/slideshow-random?noredirect
pass: abc
Here you can add Caption over image.
This requires some customization on the site so if you want to apply it you can add me as a contributor, I will add the code and guide you to add it to the slideshow
Thanks for the offer of help. This is the current format of my slideshow which I’d like to keep – assuming I can just move the captions in your example with some css?
Also, I tried the plugin for randomizing galleries and it didn’t work (SQSP themes or something), and I’m thinking it’s because my gallery slideshow is a section, not a block. Will that be an issue with your method?
I also use SQSPTHEMES, it works with Gallery Block only. You can consider using Gallery Block Slideshow
Hello, can I use this code for a simple grid gallery ?
Thank you
With Gallery Section Grid, use this code
    const productGrid = document.querySelector('body');
    if (productGrid) {
        var productItems = productGrid.querySelectorAll('.gallery-grid-item');
        for (var i = productItems.length; i >= 0; i--) {
            productGrid.appendChild(productItems[Math.random() * i | 0]);
If you need to do this for specific gallery, just change
body
to gallery grid id
or share link to page, I can check & give you exact id/code
Thank you for your answer. I can’t seem to make it work though :frowning:
I’m still on a trial version. But here are the two id section number I see for this section
#collection-67b5f9cb88299161acd3e9ca
section[data-section-id=“67dbf47a7a67a8523d8287e3”]
Not sure how to integrate it in the code you gave me either.
I just want this specific shuffle effect on this page. To do so i can imagine that i have to integrate the code in the advanced section of this specific page?
Do you have link to Pub page?
and you need to add code to Code Injection > Footer to make code load properly
can you use this link? its a trial version
What is pass?
Hello Tuan Phan, can I send you the password by mail?
You can use this code, if it doesn’t work, send password to my email
    const productGrid = document.querySelector('#collection-67b5f9cb88299161acd3e9ca .gallery-grid-wrapper');
    if (productGrid) {
Ohhhhh thats fantastic. It works!!!
I’m so happy. It’s exactly what I wanted to achieve.
So grateful
