To limit quantity on Product Squarespace, you can follow these.
#1. One Product
First, you need to find Product ID.
In my example, it is: #item-674d9b1537f5e2577fa97006
Next, use this code to Code Injection > Footer
document.querySelectorAll('#item-674d9b1537f5e2577fa97006 .product-quantity-input input').forEach(input => {
input.value = 1;
input.setAttribute('readonly', true);
input.style.pointerEvents = 'none';
Remember to change Product ID in the code.
This code will set Quantity always show 1. Users can’t increase it.
You can change 1 to another number.
#2. Some certain products
You can create a tag with name: limit-quantity and assign it to products.
Next, use this code to Code Injection > Footer.
document.querySelectorAll('.tag-limit-quantity .product-quantity-input input').forEach(input => {
input.value = 1;
