How to create floating calculator using Popup widget
Want to display your Calculator as a floating window?
While this layout isn’t available in the Calculator widget by default, you can create it using the Popup widget as a workaround. Follow the steps below to set it up :backhand_index_pointing_down:
Create your Popup widget
Create a new Popup widget and select the layout that fits your needs.
We also recommend enabling the Reopen button so visitors can open the form again if they accidentally close the popup.
Configure Popup settings
Open the Settings tab and customize when and where your popup should appear:
  • Set the display frequency
  • Choose the pages and devices where it should be shown
  • Add display triggers or schedule if needed
Add your Calculator widget to Popup
Copy your Calculator widget installation code:
Then open your Popup widget, add an HTML block on the Builder tab, and paste the code there:
If a horizontal scroll appeared, adjust the widget’s width on the Layout tab:
This video demonstrates how the floating calculator appears in 5 seconds after the page load:
Guys, was this solution helpful? Let us know in the comments :slightly_smiling_face:
