To add Social Icons to Main Navigation Squarespace, you can follow these steps.
#1. First, EDIT SITE HEADER
#2. Click ADD ELEMENTS
#3. Enable Social Links
Result
#4. To add a space between Social Links – Navigation, use this code to Custom CSS box
div.header-nav-wrapper {
margin-right: 3.9vw;
#5. To edit Social Links , you can click on Social > Click Edit
and you can add more links or remove links here
#6. On some smaller screen, you will see overlap between Nav links – Social Links, you can use this code to Code Injection > Footer to prevent this.
$(document).ready(function(){
$('.header-display-desktop div.header-actions-action--social').appendTo('header#header nav');
<style>
header#header nav .header-actions-action--social {
display: flex;
flex-direction: row;
header#header nav .header-actions-action--social a {
margin-left: 1.1vw;
margin-right: 1.1vw;
header#header nav {
flex-wrap: nowrap;
align-items: center;
</style>
