How to add Blog to Homepage Squarespace
To add a Blog to the Homepage in Squarespace, you can use one of 2 options:
  • Option 1: Set Blog Page as Homepage then design blog page layout.
  • Option 2: Use Summary Block on the Homepage and pull posts from the Blog Page
Option 1. Set Blog Page as Homepage
#1. Hover on the Blog Page > Click the Gear icon
#2. Click Set as Homepage
#3. Confirm
#4. Next, open the Blog Page and click EDIT
#5. You can ADD SECTION and design the Homepage like how you design a standard/blank page
Option 2. Use Summary Block on the Homepage
#1. Edit Homepage > Click Add Section
#2. Choose Blank Section
#3. Click ADD BLOCK
#4. Choose Summary
#5. Edit Summary > Select a Page
#6. Choose a Blog page you want to add to the Homepage
#7. Next, click Design and adjust layout/style
