How can I install audio widget on Notion?
I tried several times to install my audio widget on Notion. But all failed.
I followed manual on FAQ but also failed.
Plz tell me how to install on Notion.
Hey there @Tomi_LEE and welcome to Community :wave:
I have to say that installation links weren’t working indeed, that’s why your widget wasn’t displayed Please accept my sincere apologies for any inconveniences it might have caused.
However, we’ve fixed the issue and everything should be fine now. Could you please check your widget and let me know if it worked?
Hi, thank you for your kind reply. I solved the problem.
But there is another problem from youtube widget.
I added below codes on Notion several times but all failed again.
Can you fix it for me please?
Hi @Tomi_LEE :wave:
Glad to hear that the Audio Player issue is resolved!
As for the YouTube Gallery widget, could you please send me a direct link to your Notion page? I’ll be happy to look into this for you :slightly_smiling_face:
Hi, thanks for your support.
notion page : https://www.notion.so/columbooks/test-page-e49779d2103949cf9a733c9fb5e374e6
BTW, I checked pricing table, and I found that maximum widget per app is 400.
I’ve been preparing mp3 files on each book for foreign languages. And we have more than 5,000 books and that mean I need more than 5,000 audio player widgets but can not purchase plan due to lack of widgets. Is there any way to increase widgets per app?
@Tomi_LEE I’ve checked your page and found Widget Not Found issue:
It means that the widget was deleted. Could you please specify which account is associated with this widget?
As for the increased number of widget, our Enterprise manager Sofia will be happy to help you. I’ve informed her about your case and she’ll reach out to you at the earliest convenience :slightly_smiling_face:
