Help with Store Locator issues
Hi everyone ..
I have some Problems and some needs ..
The problems are:
  • When I move the widget with the mouse scroll the widget cover the header of the website on mobile.
  • When I click on any location its Popup disappear and when I search inside the page I found that it is jump to the top of the website above the “Header”.
    "I discovered the reason, which is that when the height of the widget on the tablet is exceeded, the popup rises to the top and appears inside a transparent black frame, so what can I do, i return back the highest and the popup return back but the highest in the Tablet still too long at the bottom covering the footer of the website.
What I need is:
  • To Decrease the zoom of The Map to show the whole country.
  • Improve the search feature so any one can search with any word of the location’s name to find it very quick, coloring the search word in the list, and limit the search to the locations that registered in the widget only.
Hi there, @Shaymaa_Alshenqiti :waving_hand:
Could you please send me a link to the page, where your widget is installed? I’ll be happy to look into this for you :slightly_smiling_face:
