Add this code to the Custom CSS field on the Style tab of your Store Locator widget’s settings:
.global-styles,
[class*='location-card-popup'] {
max-height: 500px;
.global-styles,
max-height: 500px;
hello, can you help with the global height of the widget …?
EDIT : found the solution thanks to you :
.global-styles,
[class*="widget__Container-sc"] {
width: 600px !important;
I changed width by height
Sorry for the delayed response, but I am happy to see that you’ve already found the existing solution.
If anything else comes up, we’re always here to help ![]()
Hi @Max
This works well.
Is there code to change the width?
I tried the same code and tweaked it to “max-width” but it never gets wider than the default width. Though, I could make it less than the current default width.
___
m.x. ![]()
Hi there, @iammasterweb ![]()
To make it wider, you can simply use width instead of max-width in your CSS code:
.global-styles,
width: 700px;
Give it a try and let me know if it helped ![]()
Thanks @Max
Worked perfectly.
