Help with code
I accidently removed the code to get all the form info sent to my email after its submitted. I still get a email, and there info saved in a google spreadsheet. But I now cant see each form field in my email like I used to.
Hi there, @Reece_Watkins :wave:
Could you please send me a link to the page where your widget is installed or just specify its ID?
I just need the original code. Nothing fancy just what was pre plugged in
If I got you right, you’re talking about the [form-data] mail-tag. I’ve added it back to your widget and now everything should be working fine:
Please check it out and let me know if you see the form fields in the email submissions :slightly_smiling_face:
