Header in Results Section
In Calculator is it possible to put a text field or header in Results section?
Welcome to the Community, @Troy_Zoschke! :wave:
You can add the heading to your Calculator widget right in the widget settings. Just go to the Build tab and open Results Section:
Here you’ll be able to add the heading:
Please let me know if this helps :innocent:
Thank you for your response. I realize I shouldn’t have used the term “header.” I’ve been asked if it’s possible to include multiple section titles within the results area. These section titles would appear inside the results section without a total associated with them. While I can create a blank calculation, it still displays a dash where the total would normally go. Additionally, I’m unable to adjust the formatting to make it look like a proper section title.
@Troy_Zoschke, thanks for your clarifications! :pray:
Unfortunately, at the moment, there is no technical opportunity to add the text/heading to the results section. Please leave a vote for this feature here Text field, and we’ll keep you posted on the progress :raised_hands:
A for the formatting issues, could you please provide more details on what exactly is wrong and how you would like to display the section title? Any screenshots would be highly appreciated!
