Hashtag Function not Working / bugging out?
  • ** yesterday we began use to use this Widget and began to encounter a bug in the Instagram Feed Widget. Just as we started to link the hashtags.
We are using it on this Site Lieblingsorte - Städtepartnerschaft Beckum
Currently in our backend part we have 4 Hashtag listed that the gallery should show, but only 2 of them are working. The Hastags we are using are:
#lieblingsort_beckum (X)
#lieblingsort_heringsdorf (X) #lieblingsort_lacelle
#lieblingsort_grodkow
(X) Marks the one that are currently not functioning.
All Hashtags are working completely fine on Instagrams end and can be browsed on every device.
The Devs/Support Team are sadly not answering on any platform so i thought i would try to get some help on here :slight_smile:
Thanks in advance**
Hi @user3577, welcome to the community, happy to have you with us! :slight_smile:
I’m so sorry that our widget is not working as expected, but worry not, we’ll make sure to provide you with the best solution.
I see that my colleagues are already working on your request, so they’ll get back to you in your support ticket with the solution any time soon :slight_smile:
