To add grid simple or grid overlay under Portfolio Pagination, like this.
#1.1. Click Gear icon on Portfolio Page
#1.2. Click Advanced > Paste this code
- If you use Personal/Basic Plan and your plan doesn’t support Injection, see #3.1
<!-- 06.26c23v7 - Grid under Portfolio Pagination -->
window.PortfolioThumbsConfig = {
paginationSelector: '.item-pagination[data-collection-type^="portfolio"]',
layout: 'grid'
<script src="https://code.beaverhero.com/portfolio/0626c23v7gridunderportfoliopagination.js"></script>
#2. Customize
#2.1. To change layout from Grid to Overlay, like this
You can change Line 05
layout: 'grid'
to
layout: 'overlay'
#2.2. To remove scroll bar appears in bottom of Portfolio Detail Page, you can use this code to Custom CSS
section.item-pagination + div#gridThumbs {
width: auto !important;
#2.3. To reduce space between Pagination – Grid Thumbnails, use this code to Custom CSS
width: auto;
padding-top: 10px !important;
padding-bottom: 0px !important;
#2.4. To change number of columns, gap between item, image ratio
You can change layout on main Portfolio Page to Grid Simple then adjust option
Then adjust layout to previous layout (ex: If you use Hover: Background, you can change to Hover: Background), then click Save
#3. Other
#3.1. If you use Personal/Basic Plan and your plan doesn’t support Injection, you can edit Site Footer
Add a Markdown Block
Add this code into Markdown
layout: 'grid'
