You can follow these steps to change Portfolio Page Hover: Background, Hover: Fixed, Hover: Follow Cursor to Grid on Mobile.
#1.1. First, make sure you used Portfolio Hover: Background or Hover: Follow Cursor or Hover: Fixed
#1.2. Click Gear icon on Portfolio Page
#1.3. Click Advanced > Paste this code to right box
- If you use Personal/Basic Plan and your plan doesn’t support Injection, see #3.1
<!-- 06.26c20v1 Portfolio Hover BG to Grid -->
window.PortfolioGridConfig = {
enableBelow: 767,
columns: 2,
gap: 12,
sidePadding: "2vw",
topPadding: "6vw",
showImages: true,
imageRatio: "4 / 3",
titlePosition: "below",
imageWidth: 750
<script src="https://code.beaverhero.com/portfolio/0626c20v1portfoliohoverbggrid.js"></script>
#2.1. Change number of columns at Line 05
columns: 2,
#2.2. Change gap between items at Line 06
gap: 12,
#2.3. Change space on left/right of mobile grid, change Line 07
sidePadding: "2vw",
#2.4. Change space on top of grid, change Line 08
topPadding: "6vw",
#2.5. Change image ratio at Line 10
#3.1. If you use Personal/Basic Plan and your plan doesn’t support Injection, you can add a Section under Portfolio Hover Background
Choose Add Blank Section
Click Add Block
Choose Markdown
Paste this code into Markdown
enableBelow: 767,
columns: 2,
gap: 12,
sidePadding: "2vw",
topPadding: "6vw",
showImages: true,
imageWidth: 750
<style>body:not(.sqs-edit-mode-active) section:has(.portfolio-hover) + section {display: none !important;}</style>
