Issue description:
Goolgle Review Score Widget appears then disappears on Wix webpage. I have updated the HTML code to the current version and have the same issue. When the page loads, you can see the Google Review Score for 1 second, then it disappears. If you reload the page the same behaviour is observed.
Hi there @J_Clifford ![]()
I’ve checked your website and don’t see this issue on my end. However, I see that the review popup is displayed incorrectly:
This happens because Wix CMS is built on iframes. To resolve this issue, you should reinstall the widget avoiding iframes - Installing Elfsight widget on Wix avoiding iFrame - Elfsight Help Center
Thank you Max! Very much appreaciated!
I will look into that
