Form Builder - simple calculcation
Adding a simple calculation between two input fields with dynamic result in a third field, i.e., Loan value - deposit value = amount to borrow.
I really like your idea, many thanks for sharing it with us!
We will try to think this opportunity over and hopefully, we’ll be able to implement it in one of the future updates. We’ll keep you informed about any changes here!
Also, I’d like to let you know that we are working on the Calculator app. Feel free to check the dedicated topic, share your ideas for this app or just vote to keep tabs on it :slightly_smiling_face:
Add the ability to perform calculations in the form based on the client’s answers and block the form depending on the outcome.
@Jb_Vargas Thank you for sharing your idea with us!
We’ll try to think about this feature and I’ll make sure to update you here in case of any news :slightly_smiling_face:
I LOVE the calculator live price update, but want to have the creative freedom and more in-depth customisation of multi-page forms. I need the two merged so you can use the selections from the multi-page form, and add a pricing page at the end which they can then use to book, basically need the addition of calculations into the form builder. This would make my year, thanks :slight_smile:
