I’d like to see the conditional logic feature for forms fields
Hi @Darryl
That’s possible, or what do you mean exactly?
Like the normal forms, only display this field, if this conditional field is *** fulfilled as an example
Do I understand correctly that a form field should be displayed according to the condition of a calculation?
That would be a preference, yes
Friends, we’ve started working on this feature and it’s in the Development stage now! ![]()
We’ll keep you posted on any progress here ![]()
Fantastic News!
Thanks max, this is excellent and even better than I thought possible with the option of conditional from the form crossing over to the calculator as well.
Hi @Darryl ![]()
We are truly happy that the feature you’ve been patiently waiting meets your expectations. A huge thank you for your lovely feedback ![]()
