Advanced Conditional Format (forms/calculator form etc)
It would be good to have advanced conditional format per field, rather than just ALL or ANY, this would mean you could select per question, so you could build it like, if X is YES & Y is NO then display Z, this would mean each field would have the option of a specific conditional format.
Hi there, @Darryl :waving_hand:
I’ve just to implement the logic you’ve described and it’s working fine:
Could you please check it?
If I misunderstood your idea, please share a specific example from your widget :folded_hands:
Hi Max (sorry for the delay - been very busy), I’ve had a chance to think about this more - if you see my build on this example - elfsight-app-13a514ce-be3d-4c96-b53d-9f0088f8bd16 I’ve had to duplicate a lot of scenario’s. Therefore rather than only the option of either (any) or (all) that an additional option of (if) could be added to all APP’s that contain a logical option, as in this example the calculator & hopefully future calculator form (which currently and frustratingly doesn’t have any conditional formatting available)
Hi @Darryl :waving_hand:
Thank you for the feedback
The additional “If” condition is available in all apps with the form element, except for the Calculator, where the conditional logic is available only for the calculator fields.
As I’ve mentioned earlier, we do have plans to add this logic in the future and we’ll keep you updated in this thread - Conditional logic for form fields
