An error occurs when trying to connect the integration.
{“error”:{“code”:400,“message”:“Service is unavailable now”,“exception”:“Client error: POST https:\/\/www.googleapis.com\/oauth2\/v4\/token resulted in a 400 Bad Request response:\n{\n "error": "invalid_grant",\n "error_description": "Bad Request"\n}\n”}}
The previous table works: https://docs.google.com/spreadsheets/d/1AoaZZ3NGtElSVM-jbjAf-6t3lhBATr6hrUP5V0yILCU/edit?gid=0#gid=0
Hi there, @Alen and welcome to the Community ![]()
I see that you have 2 Form Builder widgets in your account. Could you please specify the name of the widget where this issue occurs?
Widget name FIW-Expo
Thanks!
We’ve cleared the authentication data in your widget and everything should be working fine now. Please try to reconnect the Google Sheets integration and let me know how it worked ![]()
Everything works! Thank you very much for your help!
No problem!
If any assistance is needed in the future, we’re always here to help ![]()
