Follow up questions in AI CHatbot
When Chatbot answers a question/message it should be able to also ask a question or give a suggestion based on visitor question so that he will continue interacting. Like for instance … What are your prices? After answering this it could continue asking, “Do you want me to compare our prices with competitors?” Or when someone asks if your music is any good after answering it, it could also ask something like “Do you want me give you a link to check our music demos?” or he could ask “What kind of music are you mostly interest in?” The purpose is to not let the visitor go away soon!
Hi there, @Panagiotis_Bitzenis :waving_hand:
Glad to say that it’s possible to achieve by adjusting the Instruction or adding the necessary info to the Q&A section!
For example:
Question
Answer:
Correct response + the needed question at the end.
Give it a try and let me know if it worked for you :slightly_smiling_face:
Thanks! How is this syntaxed? Regards.
Just add the question to the Question field of the Q&A section and add an answer with the follow-up question at the end to the Answer field:
Please let me know if it helped or if you have any questions left :slightly_smiling_face:
