Floating position in middle left
Need to be able to place floating widget at middle left of page. Currently only able to choose bottom left or right.
Hi @Steven_Johnson
Thanks a lot for your comment! Just to be sure, under middle left you mean this position?
Friends, great news: this feature request is in the Design stage now!
We’ll keep you updated on the progress :slight_smile:
Update: the feature moved to the Development stage! :tada:
Hey everyone!
We’ve released flexible position settings for the badge layout. Now you have full control over their position — set them to the left, right, center, top, or bottom of the page.
You can also adjust the vertical and horizontal offsets using slide controls. Review Button Badge has a built-in middle left position:
Compact Badge and Card Badge layouts don’t have this option, but you still can place them in the middle left position. For this, choose top/bottom left position and manually input the vertical offset value that is beyond the slider limit:
We’ve also released a bunch of other cool features for the Badge layout. Check this post for more details - Reviews: [MAJOR UPDATE] New badge designs, flexible position adjustment, display triggers and more!:fire:
