Floating bubble customization
I’m encountering a similar issue where I lack control over the positioning of the WhatsApp widget. The limited options available restrict its placement, causing interference with other widgets such as the announcement bar when placed at the bottom, ultimately concealing the WhatsApp widget.
Hey there @Haytham :wave:
Happy to tell you that we have a solution - Place widget higher
Please check this code and let me know if it helped :slightly_smiling_face:
