Hi. Is it possible to have the calculator load at the same time as my website does or at least faster? There is usually a bit of a delay between the time my website loads and the time the calculator loads.
Hi there, @user40650 ![]()
This slight delay might occur because of the data-elfsight-app-lazy atrribute in the installation code, which causes the widget to load only after the first user interaction (like scrolling or moving the cursor):
If you’d like the widget to load much quicker with the page content, simply remove this attribute from the code. Give it a try and let me know if it helped ![]()
Hi. Thanks, it is loading a bit faster now. The delay is still there, however.
Got it, thanks!
To make the widget appear even faster on the page, please move the first line of the installation code to the website <head> as high as possible.
Here’s what the first line of the code looks like:
<script src="https://static.elfsight.com/platform/platform.js" async></script>
As for the second line of the code, it may remain untouched where it is added now.
Give it a try and let me know if it worked ![]()
