If there are no events in the current month, but you want to showcase the month with events, we’ve got a solution!
Our devs have come up with a custom script that identifies which month in the calendar has events and switches to that month.
Here is the script you need to add right after the widget installation code:
window.onload = () => {
let eventsInCalendar = 0;
const myInterval = setInterval(() => {
const calendar = document.getElementsByClassName('fc-daygrid-day');
let eventInTheCurrentMonth = false;
for(let i = 0; i < calendar.length; i++) {
let month = calendar[13].getAttribute('data-date').split('-')[1];
let currentEventMonth = calendar[i].getAttribute('data-date').split('-')[1];
eventInTheCurrentMonth = month == currentEventMonth;
if(calendar[i].innerHTML.includes('fc-event-start') == 1 && eventInTheCurrentMonth) {
eventsInCalendar++;
if (eventsInCalendar == 0) {
const buttonNext = document.querySelector('[class*="next-button"]');
buttonNext.click();
} else {
clearInterval(myInterval);
}, 300)
Note: This script works only for Month layout
Have questions or need assistance? Share your use case in the comments and we’ll gladly assist ![]()
