Issue description: Reviews testimonial slider widget makes my homepage display too wide and screen can slide from side to side.
is there a setting i can use to modify the width of the widget ?
Is this on mobile, desktop, or both?
Hi there, @Juan_Colome ![]()
Could you please send me a link to the page, where your widget is installed? I’ll be happy to look into this for you ![]()
Sorry for the delayed response. I will send you the link tomorrow
Thank you
Just mobile
